I'm looking to hang my tv on a bedroom wall however there is only one stud on that wall. I tried using a snap toggle but behind the plaster, there's concrete that won't allow the snap toggle to fit. The tv is pretty light it's around 15-20 pounds. Is there any other way to go about this?
    There are several answers on here that explain how to mount a piece of plywood so it spans two ( or more ) studs and then mount the tv to the plywood. Use the search function. – Alaska Man Aug 19 '19 at 18:19
    I have had mounts for smaller tv’s that only required 1 stud you may look into a different type of stand. – Ed Beal Aug 19 '19 at 18:35
    One stud should be plenty for such a small TV - why is that not an option for you? – JPhi1618 Aug 19 '19 at 19:42
  • you only need 1 screw into the stud to keep the TV from falling off the wall .... a second screw positioned anywhere would keep the TV from rotating around the first screw – jsotola Aug 19 '19 at 21:36
  • you can use thumbtacks for that kind of weight. I had rear home theater speakers held up by them, 6 tacks each. The speakers were about 10 lbs each. – dandavis Aug 19 '19 at 22:19
