I've moved into a new home here in central Florida, and had a new AC system installed.
They attached the drain line to the old existing pipe that was there with the old system.
Unfortunately, this pipe doesn't have a very good slope to it before it runs under the house and then back up and outside. Because of this I always seem to have an issue with clogged pipes.
I think a good solution for me would be to make a new pipe and reroute it along the back side wall of my garage with its own natural slope then going through the wall of the garage outside.
I was wondering if this is okay or does the pipe need to go underground under the house and then up and out?
