I have EMT leading to a metal junction box, and from that box goes plastic liquid tight to some equipment. Currently I have a ground conductor running all the way back to the panel, but I'm wondering if it's enough to terminate that ground at the metal junction box (so that the EMT back to the panel forms the remainder of the equipment ground).
Related question: how do I properly bond the 10 ga grounding conductor in the liquid tight to the metal box? Crimp a ring terminal on it?
