The Viega Manabloc is an example of a system in which a central valve manifold uses a dedicated tube for every fixture in the house, as alluded in the comment from BillDOe.
In some US homes it's not a difficult retrofit to split the house into at least two zones. Typically the water service enters an unfinished "utility closet" space where the water heater is also located. There will be a few tees and water pipes head off in different directions to the master bathroom, kitchen, other bathrooms, etc. These pipes could be cut and valves inserted so that water can be shut off somewhat selectively.
In my own house I reconfigured the plumbing in the utility room. I have the kitchen and basement bathroom on one pair of valves (one each for hot and cold) and the laundry and other bathrooms on a different pair. These are arranged neatly beside the water heater. This has allowed me to defer replacing the shutoff under every sink and toilet, which always seem to be jammed and/or corroded to the point that they can't be shut off when it's needed most.
It's not as fine-grained as the manifold approach, but routine plumbing repairs are far less stressful when at least one toilet in the house remains functional!
Now, to actually answer your question. It cost less than US$100 in parts and several hours of work to make that change in my house. Doing the work that way during original construction would cost almost as much. It doesn't happen because the home buyer doesn't want to pay extra for it, the builder doesn't want to pay for it from his own pocket, and the plumber isn't going to do this premium/extra work for free.
