(https://i.stack.imgur.com/Y7RKV.jpg)
(https://i.stack.imgur.com/yb0Ns.jpg)
I am trying to reconnect the wires for this outlet but have run into an issue. The pictures above were taken before everything was disconnected, however the wiring in the wingnut with in the box was disconnected before a better picture could be taken.
This outlet is under the kitchen sink for the garbage disposal and dishwasher. Each has their own circuit breaker. The garbage disposal is running off a switch while the dishwasher is always hot. There is a three wire and two wire bundle running into the box.
It looks like red and white from the three wire are running into the outlet. Black from the two wire is also running into the outlet. The grounds are all wingnut it together.
What I want to verify is would it make sense in this arrangement for black from the three wire to be wingnuted to white from the two wire? This appears to be what is going on in the image, however I don’t want to connect it and risk burning out any wiring when the breakers get switched on if this would not be correct.
