I have a gfi receptacle I am plugging a drop cord Into it and running it to a box with a switch and gfi receptacle in it. I am plugging a pump into this gfi. Will this work
1 Answer
It might work but would not be code compliant and with 2 GFCI’s on the same circuit you may have nuisance tripping. If you test the GFCI at the box it may trip that one and the one inside.
