I have a wood cabinet that I am redoing (painting and changing door hardware and removed interior shelving) to use as a TV enclosure in my family room. The house was built in 1940 and has plaster walls. My plan was to mount the cabinet into the wall stud and then mount the TV (20 lbs) to the back of the cabinet which is 1/2 inch VC plywood. However I cannot find a stud in this small section of wall. I’ve read that sometimes small wall sections against a masonry exterior might not have a stud. I’m using a magnetic studfinder (studpop) and I can’t find any stud. What’s an alternative way to do this?enter image description here
There are probably king/jack studs on each side of the window plus a sill and a header. Your magnetic stud finder might not be strong enough to go through the plaster. They're good for finding drywall screws covered by joint compound but that's about it. So you either buy a more expensive stud finder or start drilling really small holes hoping to find the studs.
Will the cabinet only be supported by the screws into the wall or will it also have legs? You can always use toggle bolts through the cabinet and through your wall.
  • Thanks for the help. To answer the previous question, the cabinet is freestanding on legs. I just feel it will be a more secure setup with the TV mounted inside on a pull out mount for it to be securely attached to the wall behind.
    – Mag
    Aug 10, 2019 at 21:27
  • No matter what my stud finder says, I always drill pilot holes or use a finishing nail to make sure I'm near the center of the stud if I'm going to hang anything with some weight to it.
    – SteveSh
    Jan 8, 2020 at 13:23
A magnetic stud finder will do good on metal framing, but not wood framing unless you happen to find the occasional nail that holds the wood lath o that is part of the makeup of plaster walls in that time frame. There may be rock lath instead but the nails will so far under the plaster it is highly unlikely to find them still.
The most effective way to find the framing with no cost, other than a large nail (2-3" long) and poke the nail through the plaster to hopefully hit a stud. Look in the most obvious places first. That is the area under the window, under either side of the window, typically, there is framing that runs floor to ceiling that is on either side of the window.
Lay out where you cabinet will be and probe in those ares covered by the cabinet.
There is a chance there are firing strips not studs if the masonry walls are 8" thick. There is a chance the walls are rock lath and plaster instead of wood lath and plaster. If the walls are rock lath and plaster and you miss the stud, the probe (nail if you choose) will go in quite difficult for about 1/2" then go into a hollow spot quite deep maybe over 3". If it is firring strips over full masonry, it will only go in 3/4" into the hollow space. If it is wood lath and plaster, and you miss the stud and the wood lath, it will do the same. There is a very good chance you will it the wood lath since it covers better than 80% of the walls. If you it that, the wood will spring back on you after you go in about 3/8" . If you hit a stud in either case, rock or wood lath, you will hit a solid object that the nail will penetrate in, but with only real solid hits with a hammer.
wall framing
Another way is to look for the minute "dimples" where the nails are that hold the trim onto the wall.
  • So when I try using a long nail to probe, how will I know I’ve hit a stud? Will the nail stop? There’s no plumbing for sure on this wall but is there anything else I need to worry about hitting or that I would hit that might not be a stud? The exterior side of the wall is brick.
    – Mag
    Aug 10, 2019 at 21:48
  • I edited the answer, since it would not let me have that many words in the comments. Try looking for the recesses left by the nail heads as mentioned in the answer under the picture I posted
    – Jack
    Aug 10, 2019 at 23:35
  • @Jack - what do you mean by "rock lathe"? Is that like a cement board with the plaster on top of it?
    – SteveSh
    Jan 8, 2020 at 13:25
  • @SteveSh It's part of the evolution of plaster/drywall. Around the 1920s, maybe later, wood lath was starting to be replaced by sheets of material that measured 16"X48"x3/8" thick. That is the forerunner of drywall, AKA rock lath, but not cement board. It had a gypsum center too, just like drywall.
    – Jack
    Jan 8, 2020 at 15:00
  • @Jack - I still have some remnants from when I demo'd the original furnace room. 3 layers, including the plaster top coat. This is from a house built in 1956. I'll take some pictures.
    – SteveSh
    Jan 8, 2020 at 19:35
