I want to switch power somewhere where power outage happens frequently from utility to inverter and back and forth kind of like a UPS without giving up on my inverter and what I already have.
  • There are inverters that will use the primary input and switch in or out other sources as necessary seamlessly. Trace spring to mind. – Solar Mike Aug 10 '19 at 14:43
    Where are you on this planet? What make and model is your existing inverter? Why do you need a 0-downtime switching setup? (Most devices any more can deal with a 16-20ms switching delay without any loss of function.) – ThreePhaseEel Aug 10 '19 at 15:37
  • Zero downtime??? Most of the switching is break before make. – JACK Aug 10 '19 at 18:20
  • What is the calculated power demand you are trying to use the inverter for? Most inverters and ups' only have a 15 or 30 minute supply at 80% of the output. How long are your outages? – Retired Master Electrician Aug 10 '19 at 22:05
As mentioned in comments, typical inverter switch times are fine for most devices.
The only way I know of to literally have NO downtime is dual-conversion, where your inverter is supplying the AC power 100% of the time, and your grid power is converted to DC and fed into the battery / DC input of the inverter.
That has built-in inefficiencies (thus, wasted power), but is "zero-switch" time as there's never a switch on the inverted power, you just go from float-charging the batteries from AC & solar to drawing down the batteries/solar.
  • Thank you, I only want to know if there is anyway to switch between grid and inverter without my modem and security dvr going down. – Superhuman Aug 11 '19 at 21:58
