I did something dumb today and I'm panicking. I tried to replace the bathroomfaucet to surprise my husband (mission accomplished on the surprised part) because it was one of his tasks before we (and here's the dumb part) list our condo so we can get a bigger place. I replaced our kitchen faucet no problem. As with the kitchen, I turned the valves under the sink so that no water came out. I pried that old as dirt faucet off the sink and then started to loosen the cold water bolt with a channel lock. When it got loose water started coming out. Like spraying water. I moved the valve around and it doesn't seem to do anything. I did manage to retighten the bolt but now we have a faucet that's literally hanging into the sink.
Now, I live in a condo and where shutting off my main water means everyone loses water, which is what I found out when I asked the hoa president if he knew where our units main water supply shut off is. I called and emailed the hoa admin to see when they would be able to shut off water but no word yet.
I'm thinking now that maybe the valve is broken (?) and may also need to get replaced. So, the question I have (and I have seaehed for this answer) is: is there any way for me to shut off the water if the valves don't seem to be responding and I do not have access to main water? I'll need a plumber regardless at this point but would rather not have to have them sit around while the main water drains.
I'm mortified so any kindness and info would be greatly appreciated
B
