My attic is a maze of wires, air ducts and PVC water pipes. I went just one room over from the attic entrance and it took me a solid 30 minutes just to go there and back. Would it be unreasonable to add some sort of pathway up there to make it easier to get around? And what do you recommend. My main concern is to reduce how much time I (or anyone) has to spend up there working. I live in Florida and the attic gets super hot. My second concern is about accidentally breaking pressurized PVC water lines that are all over the place.
It's a wood truss roof. There's lots of ridges/valleys and differences in ceiling height. So in the attic you will run into a 'wall' where the ceiling on the room below is much higher than the one next to it. It seems like almost all of the floor places that would be good to walk are obstructed with wires/ducts. There's a lot of space above that high in the air.
Looking at the first picture, the maximum width beneath the horizontal pipes and above the wiring is ~2 feet.
The air conditioner is ~14 feet long. To get into the area on the left I've just been walking all the way around the unit to the right. You come into other obstacles when you get on the other side of the machine tho.
Measured the temperature in the attic today at 1:30PM. Today was a mostly overcast day with rain. High temp is 110F. Low temp near edges of the attic on the floor was ~87F.
Update: After adding some boards in a few strategic locations it only takes maybe 1 minute to travel the distance that used to take 10-15 since now I don't have to worry about stepping/falling through drywall in a few strategic places (like turning tight corners with no room to stand).
