can Kerdi board be painted? I want to use it on the walls in my bathroom instead of sheet rock.
1 Answer
Yes you can paint over Kerdi board but you will need to give it a light coat of joint compound and do a little sanding.
1Painter here, that's what I was going to say, you can paint anything if paint will stick, prime it first and do enough fairing... (joint compound, bondo, etc) Aug 6, 2019 at 0:11
