I assume yes and there is no harm or downside, besides these screws being more expensive than non-coated screws.
Stainless steel is more brittle than the steel commonly used for screws. In some cases I have twisted off long ss screws. This may be a critical deficiency in some applications.
I use stainless steel exclusively for installing grab bars in showers. These are ss screws which come with the bars. In dry situations I use whatever I have except never drywall screws.
I once tried to use long ss screws to secure an owl box to the trunk of an oak tree and I twisted off the screws. I then used deck screws with no problem.
BoltDepot
Stainless steel is an alloy of low carbon steel and chromium for enhanced corrosion characteristics. Stainless steel is highly corrosion resistant for the price. Because the anti-corrosive properties are inherent to the metal, it will not lose this resistance if scratched during installation or use.
It is a common misconception that stainless steel is stronger than regular steel. In fact, due to their low carbon content, many stainless steel alloys cannot be hardened through heat treatment. Therefore, when compared to regular steel, the stainless alloys used in bolts are slightly stronger than an un-hardened (grade 2) steel but significantly weaker than hardened steel fasteners. Unless great care is taken, stainless fasteners are susceptible to seizing up during installation, a phenomenon known as galling.
Most stainless steel fasteners are much less magnetic than regular steel fasteners though some grades will be slightly magnetic.
  • Fully agree,+. I would use SS screws if I had them handy in just about everything. – Ed Beal Jul 31 '19 at 15:12
  • Ok so this is fine to do, just not the opposite (non-galvinized screws outdoors and/or in pressure treated wood)? – jordan Aug 9 '19 at 18:24
