I am looking for something to attach to the exhaust of this bench grinder to catch the particles, especially the side with the grinding wheel.
It's making a big mess of particles.
It was a "flea market special" I bought about 40 years ago.
I am willing to make something if need be.
Thanks.
    try a magnet .... will not work on non-ferrous materials though .... maybe some sort of a tube that leads into a container ... maybe made from canvas .... not sure how it would stand up to sparks
    – jsotola
    Commented Jul 30, 2019 at 2:02
  • @jsotola Not sure how well a magnet would work as the wheel is rotating at 3450 rpm. The bag is a good idea.
    – fixit7
    Commented Jul 30, 2019 at 9:55
  • What's the question? Fashion or procure some flame-retardant bags and zip-tie them on there.
    Commented Jul 31, 2019 at 15:52
I have a metal dryer hose connected to my grinder that drop into a bucket. I would not use a bag if you grind ferrous metals the hot sparks could catch the bag on fire, I used to have my grinder connected to a shop vacuum until I set the vacuum on fire. Having the larger pipes drop into a bucket works great, if I am really doing heavy grinding I sometimes put an inch of water in the bucket. A side note the metal filings and water really help my snow ball bush turn bright blue, a friend suggested using the steel dust and water on the snowball bush and it really helps almost like adding dye to the flowers.
Here's what I went with:
It does not look pretty, but it does work.
Many thanks to all who helped. :-)
