I'd be grateful if someone would resolve some conflicting advice I've been given on this topic.
Some argue that the braiding does not contribute to the pressure rating of these hoses, and that surface corrosion does not indicate urgent replacement.
On the other hand, online sources such as this (in addition to this study) imply the contrary, that corrosion is among the causes of braided hose failure.
What would you say is correct? Would extensive corrosion require urgent replacement?
