One of the screw holes on a junction box on my ceiling has fallen apart, leaving a hole that is too big to fix a screw into (see top of picture). As a result, I cannot hang my smoke detector from the junction box, since the detector hangs from the heads of the screws.
I was trying to see if there was something I could fill the hole with to then make a new hole for the screw. This would save me the cost and hassle of having the box replaced, which I assume would require cutting into the ceiling (the box seems to be affixed to a brace above the ceiling that runs between two joists, since all I see is the head of a bolt at the top of the box and no nail heads anywhere). Any thoughts on what I could do here?
Thanks
  • It is probably possible to remove the box and replace it without cutting into the ceiling. Also fixing hole in the ceiling is not rocket science. Attempting to fix the box is not advisable.
    – Charles Cowie
    Commented Jul 26, 2019 at 22:54
  • you see that the box is attached with a screw and you are asking what to do next?
    – jsotola
    Commented Jul 27, 2019 at 0:34
  • that screw is for the cover.
    – Jasen
    Commented Jul 27, 2019 at 4:19
    it looks kind of like plastic to me
    – Jasen
    Commented Jul 27, 2019 at 4:21
That box is a type of plastic called Bakelite. It's tough, but brittle. If you're careful, you can break the box apart without damaging the ceiling. If you have a hole saw, you can probably drill out around the rivet heads you see in the back of the box and it will come right out.
Then you can replace it with a new "old work" box.
Yep, you can fill it by tightly stuffing it with even just damp toilet paper, paper towel or napkin(s), then let fully dry and harden...a liberal coating of Krazy Glue on the first wad would help.
Otherwise, a wood putty or auto body (car) dent filler (Bondo) would likely be a more permanent solution for future smoke detectors. If you can drill small holes through the sides, then the insert of a nail or brad for the filler to stuff around will really help durability.
I'd just use a toggle bolt. No need to patch or replace the box if the outer shell is intact.
