Wiring from the Ceiling: Black Red White Copper ground
Wiring from Remote: Input side: black and white wires Output side: white, black, blue, and green (ground)
Wiring from Fan motor: black, white, blue, green (ground)
The fan is turned on from a single wall switch. I want to power the fan from the wall switch and then use the remote to change fan speed and the light.
How do I wire this combination? Thanks!
  • This is a common question here. Use the search feature to find duplicates – Kris Jul 25 '19 at 23:23
  • You may notice almost every room has a light switch in an obvious location. Building codes require at least one switch exist and turn on a light. You can't have all the lights on unusual methods. When this switch no longer operates a light, will you still comply with building codes? – Harper - Reinstate Monica Jul 26 '19 at 15:27
