In my kitchen, all our drawers appear to use a wooden rail "hanger" (at the top of the drawer) to slide in and out:
The problem is our utensil drawer is probably one of the heaviest, and it finally gave out, so I replaced it with a new rail and hanger kit from local home improvement store. However now, a month or so later, the drawer "drops down" when pushed in all the way, and the hanger seems to be worn down quite a bit:
I could replace the hanger again, but it seems like something is inherently wrong here. I'm guessing the wood/plastic hanger system isn't quite meant for a heavy utensil drawer, and there's some better solution? A general contractor wanted an enormous sum to even come take a look, so I'm hoping you kind folks might have some advice. Thanks!
