I'm planning on taking a few weeks off to do some DIY in the fall, and one of those things is replacing the standard-hinged door in my walk-in closet with a pocket door. This is a non-load bearing wall, so I don't have to worry about that at least!
I'm researching how to do this, and most of it seems pretty straightforward. Cut out the drywall on one side, cut out the studs, put the pocket door frame in place, liquid nail the inside wall to the pocket door frame, hang the door, liquid nail the drywall patch to the door frame, mud, paint.
I'm familiar with most of this, however I'm stuck at cutting out the studs. I know I can use a circular saw set to a very specific depth to cut the studs, but the opposing wall should be screwed to the ~6' section of the studs I want to pull out. Am I just supposed to rip out the screws and patch the other side as well? Is there some other way I can cut the screws without damaging the opposing wall?
