I am trying to figure out how to calculate the total equivalent length of a loop with cast iron radiators. The pipes and fittings are easy to calculate because pipe is calculated linearly, and the fittings are just looked up in a table, but how should the radiators be included in this? How does one figure out how many feet of head to add to the loop to account for the radiators?
A quick and simple google search gives : runtalnorthamerica.com/commercial_institutional/…– Solar MikeCommented Jul 17, 2019 at 7:29
That link is for the new style runtal radiators, as opposed to the old style cast iron radiators.– zelinkaCommented Jul 17, 2019 at 14:52
But if you understand the theory and the formula (like how to calculate pressure drop using the friction factor) then it is possible to adjust or re-work for any type of radiator or device that causes a pressure loss.– Solar MikeCommented Jul 17, 2019 at 14:55
Add a comment
1 Answer
The standard way to treat a radiator is to pretend like it is a piece of straight pipe, so if the radiator is 4 feet long it counts as 4 feet of straight pipe.
I got this information when I asked a hydronic heating specialist how one does this calculation.
