I'm looking at a wooden wardrobe, which has... well, seen a lot of punishment. But in this question I'm focusing on how its side was splattered/stained with white material which is either whitewash, or more likely, in-door wall paint.
I started by scrubbing (sort of) gently, with a rag. I then went on to make the rag moist and scrub again. I continued with applying some mild pressure through the rag (mostly to the areas with thick stains). These stages all helped, but a lot of white was still left. I tried scrubbing somewhat harder, and also scrubbing more gently, but with a (non-metallic) scouring pad. That also helped a bit, but I'm really not there yet.
I feel I was already kind of pushing it with the scouring pad, and hurting the varnish. I'm wondering - what should be my next step? I'm guessing some sort of material compound should be able to loosen/disintegrate the white splatter without affecting the wood/varnish much. Am I right? If not, what else should I do?
Here is the wardrobe side's original state:
and here is the current state (possible variations in lighting):
PS - Wondering about the gray swath at the bottom? 1. It's not my doing. 2. Just don't ask, I'm still traumatized by that. Suffice it to say some people should be behind bars for crimes against aesthetics and workmanship.
