I've noticed some apartments that use both for water supply to faucets and toilet cisterns.
I understand that the braided hoses are rated for higher pressures, but how do they compare in terms of durability at typical static and dynamic pressures?
Is it correct to consider the EPDM layer in braided hoses, by itself (minus the support of the stainless steel braiding), to be equivalent to a rubber hose in terms of pressure resistance?
