I'm installing a floor with 1/2" engineered hardwood. This is the stuff that's basically tongue and groove plywood with a small layer of nice finished hardwood as the top layer. I've purchased a floor nailer to do the job. Unfortunately, the flooring staples always seem to be going too deep. The one exception was too shallow and at an air pressure well below what the tool specifies as the minimum.
Ultimately, I'm not sure I'm actually using the right stuff to secure the floor. The manufacturer was not specific with their instructions.
This is an example of what happens when the tool is run at normal power. This particular example was about 85 PSI. The tool specifies 70-100. Too deep, 70 PSI
I dropped the pressure below the minimum in an attempt to get better results. This was around 40 PSI, well below the tool's stated minimum. Too shallow, 40 PSI
This is a cross-section of the flooring I'm installing. With the angles on the edge, there isn't much except the tongue for the stable to grab in to anyway. Going deep enough to avoid blocking the next piece at the top seems like it will always end up splintering the plywood. Cross-section
These nailers are made to handle solid wood flooring and thick subfloors. Your engineered floor is much easier to nail, and you may have a pretty "soft" subfloor as well (not a bad thing, necessarily, just saying that it accepts nails pretty easily). The max PSI is important because that is the MOST the tool can handle without blowing seals, etc.
Don't pay attention to the minimum. On nailers, that is a "best guess" for the PSI needed to do a typical job so you can make sure the compressor you have will be enough. It's not like you will hurt the nailer with low pressure. A nailer might work down to 10PSI if you are nailing styrofoam (not that you would want to do that).
So, play with the pressure until it's driving the staples the correct depth. However, when you use a lower pressure like that, any irregularity in the subfloor will lead to a staple that's not driven all the way. That's fine - just be prepared to manually set a staple every once in a while and don't get frustrated when it happens. Find the sweet spot on pressure and even adjust it if you get to a section of floor that starts behaving differently.
    Running it about 50 PSI seems to work. My compressor varies the pressure too much for full consistency, but using a nail set is an easy fix.
    – Elros
    Jul 14, 2019 at 0:13
That's a good question. My cursory searches of good nailers for engineered floors found a reco for a Bostitch unit with a different part number, that was for 1" #18 staples, and weighed 3.5 pounds instead of 10.5. However both nailers were the same price. So at first blush it looks like you have a beast of a nailer there.
Honestly my recommendation where power tools are concerned is to do the job by hand until your arm falls off. Then seek a power tool. Because then, you will have an educated sense of what the power tool is trying to do, so you'll know immediately if it's not doing it and have a good sense of why. They seem to recommend 1-1/4" #18 or #19 brads, which I've worked with and are rather easy to set. You can set them with a brad hammer followed by a brad setter, and they also make spring contraptions where you snap the spring to drive the brad.
I can't honestly imagine why 80 psi would be needed to drive 1-1/4" #18 brads. So yeah, I think the tool is too big. It may be appropriate to fit the smaller brads or staples and just crank the pressure way down, but I'm not there working with the tool so I don't know if that's practicable.
