I have water accumulated in my basement, that I squeezed out using towel. It was about 8 gallons of water in all. The only source I can see is the furnace whose surrounding is wet but I have never seen a running water from there other than being wet.
Previously (last year) I have seen water accumulated once due to what I thought was excessive rains but this time, it has been very dry outside.
Does this picture tells anything if this is the furnace indeed? Is the fix easy?
Update
I followed up with the answer and filled condensation pump with water. The motor does start and the tank gets emptied but what I noticed is the water starts to seeps through the furnace. I have provided pictures with red circles where water seeps.
It was difficult to determine if the water really gets out through the transparent hose which is very yellowish at this point. I watched several videos on youtube and typical issues seems to blockage of valve. Now I am not sure if that's the case given the water seeps through the furnace after pump action? Could the pump be pushing it in backward direction due to blockage?
Do you think there is still good chance I check for blockage and that could fix the issue or get new pump?
Update 2
I troubleshooted further and opened the condensation pump. The tank was extremely dirty dust collected over time over time and stuff hanging to walls and floaters. I guess that could block the valve if this stuff is getting pushed out.
I clean it, cleaned the valve and tested the condensation pump by itself and it's working great. When I fill it, the springs up the water with nice power as i have seen in youtube videos.
I put it back but unfortunately, this still didn't fix the issue! The water oozed out from furnace parts higher up after pump action.
