I recently changed out my incandescent lights in my kitchen to LED lights there are 3 lights each have 5 LED light bulbs with 2 3 way switches controlling their on/off function. I found the leg side and the power side, I was told to install the dimmer switch on the leg side but when I do that the dimmer switch only dims 1 of the 3 light fixtures> I'm trying to find out why and what can I do to correct this problem to control all of the lights connected to the switch
    A diagram of the switch and light wires showing all hot, switched hot, traveler and neutral wires would help. – manassehkatz-Reinstate Monica Jul 9 '19 at 1:04
    Can you post photos of the insides of the boxes? – ThreePhaseEel Jul 9 '19 at 1:21
    Did it work before with incandescent lights? What kind of LED did you use? Also try putting 1 incandescent in each set of 5 and report back what happens.... – Harper - Reinstate Monica Jul 9 '19 at 1:26
  • Hello, and welcome to Home Improvement. As said above, we'll need more info to be able to help you. And, you should probably take our tour so you'll know how best to participate here. – Daniel Griscom Jul 9 '19 at 1:42
