The black wire is connected to the neutral bar and the white wire is connected to the breaker. Should it be this way for any reason?
  • 4
    Not any normal reason. Can you post a picture of the panel? – manassehkatz Jul 9 at 1:05
  • That's pretty weird, no, there's no legitimate reason to ever do that. Maybe they had a black wire go bad on them and they used white for hot and bootlegged ground for neutral... – Harper Jul 9 at 1:06
  • 4
    @Harper doesn't sound like bootlegged ground - sounds like a simple reversal of black & white. Which is dangerous. – manassehkatz Jul 9 at 1:19
    Yes, can you post a picture of the inside of the panel? Also, can you find the first outlet on the circuit, and post a picture of the inside of its box? – ThreePhaseEel Jul 9 at 2:15
  • I purchased a house that was wired that way In Ohio, not just 1 but all the hots and neutrals reversed. – Ed Beal Jul 10 at 19:22
No. I suggest you test the outlets on the circuit with an outlet tester. I use the Gardner Bender GFI-3501.
