My son-in-law's Goodman B1809913S control board only has R, W and G terminals (no Y terminal). In order to make the AC compressor AND the furnace fan operate the Y and the G wires are jumpered together at the furnace end of the thermostat cable. In this configuration there is no way to control the fan independently of the AC compressor. Currently when the fan is set to "Manual" at the thermostat the AC compressor AND the fan run continuously. Not a good situation because it would cause the AC compressor to run continuously.
Is there a way to wire or configure the system that would allow the fan to run continuously without turning on the AC compressor?
