When re-opening walls for plumbing, electrical changes I elected to remove whole drywall panels, when replacing these with new panels should I present a tapered edge to the previously finished edge? Or does it now count as a "butt edge" and should I cut the drywall for a butt-to-butt edge?
I'm reading that it's more difficult to finish a taper-to-butt seam.
In one case the paper tape came up easily, should I do elsewhere?
I'll be hiring a taper/mudder to re-finish these seams.
  • Is “mudder” a plasterer?
    – Solar Mike
    Jul 7, 2019 at 17:15
  • I'll be hiring a taper/mudder to re-finish these seams. Maybe ask that person which seam style they prefer to work with?
    – dwizum
    Jul 8, 2019 at 15:11
Finishing a taper to butt seam is no more difficult than any other seam. Don't worry about it. (Especially if you've got a pro doing it.)
Any paper that lifts should be removed.
