I have 4 outlets that are dead in my 2nd floor bedroom. I checked the wiring and the wiring is dead no juice. The circuit breaker is not tripped. What would cause the wiring to die?
    Are these outlets connected using "backstabs," or the side-screws? – ThreePhaseEel Jul 6 '19 at 17:17
  • Hello, and welcome to Home Improvement. Is this a new problem, and if so what might have triggered it? And, you should probably take our tour so you'll know how best to participate here. – Daniel Griscom Jul 6 '19 at 18:06
    There may be other receptacles on this same circuit and they may be in other rooms. A place to look in another room is directly across a partition wall from a non working receptacle. If you can find a working receptacle on the circuit, and the next receptacle in order from the panel doesn't work, then you have a bad connection in one of the two boxes. Do you have a 3-prong circuit tester? – Jim Stewart Jul 6 '19 at 19:57
    Please find the correct breaker and try cycling it off and on. Some breakers can be tripped but not be visibly so. – DoxyLover Jul 7 '19 at 0:41
  • Is there a GFCI outlet between the service panel and the four outlets that are dead? – Ryan Prechel Jul 12 '19 at 3:19
