I have a Kenmore Coldspot refrigerator that has a compression male thread at the water inlet valve. The model # is 10650562991.
I am trying to connect the copper flexible tubing that you buy as a kit to the water inlet valve. The manual on line does not indicate thread size only that it is a compression nut.
I need to purchase an adapter so the 1/4" flexible copper line can be connected to refrigerator.
Can you provide me with the correct female compression nut size?
  • It looks like it should be attached to the copper line you described. manualsdir.com/manuals/666055/kenmore-coldspot-106.html?page=8 – J Crosby Jul 5 '19 at 19:41
  • You need a 1/4" compression nut and a 1/4" compression ferrule. This is with the assumption that neither you or anybody else have used any fittings or adapters when making connections to the unit prior to this effort.. – Jimmy Fix-it Jul 5 '19 at 19:47
