I stumbled across this site and think it sounds like someone might be able to help me with my problem…
Let me outline… I have a cooktop (St George CC355, if that's useful) and it has two hotplates (well three, if you count the fact that one is a dual hotplate). The dual is the problem… it used to work, then suddenly it only worked on the full hotplate setting, which is actually, both the small and large on together). Because of this, I think I have narrowed the problem down to the control or the simmerstat switch, which I would love to just be able to replace (job done), but they no longer make it and have no alternative.
So, my question is can a simmerstat switch be fixed? And how? The switch is a TDL-205 if that helps. I really hope someone can give me some advice.
Kind regards, Lyndelle.
migrated from electronics.stackexchange.com Jul 4 at 11:12
This question came from our site for electronics and electrical engineering professionals, students, and enthusiasts.
According to oxfordparts.com.au the part has been replaced/superceeded by TD3V-800K which I think is still available. I found a bunch of eBay listings anyways.
Also worth checking out this. If it looks the same as the switch you have it's probably the same
https://stoveconnection.com.au/shop/index.php/store/stove/controls/cooktop-controls/tl-205.html
Be aware the TD3V part might not look identical but the connections should be the same. Likely they improved the "guts" so they don't fail so soon... Or so that they're cheaper to build.
Don't try to fix the switch, it'll never be right and you could melt stuff. Not to mention it's likely glued together.
Good luck!
  • Thanks Andrew, I will have a look at that part and I will also ask stove connection for their advice (I think I previously asked them, but they weren't much use, however, with the addition of a suggested part, maybe they will be more useful). Don't panic… I won't try to 'fix' the part (it was just a suggestion), Cheers L. – Lyndelle McMillan Aug 19 at 1:26
Are you in Australia?
This page may have a TL205 - which is also advertised as a "divided controller".
The TDL-205 manufacturer's 2009 brochure advises that "TDL units are no longer available and that no replacement is possible" :-(
This TD3-204 is for a divided element and MAY be suitable
If you can advise connections and exact * functionality we may be able to make suggestions re alternatives.
  • EXACT detailed description of how it works.
  • Funny you should mention TL-205, because that's the control for the other burner (single medium). As for exact functionality, the way it should work is the switch operates both small & large elements. When turned to left, only the small inner element, with a top (low) to bottom (high) function, and, when turned to right, it operates both the small & large (outer) elements, same top-bottom (low-high). Presently, left hand side is not working, it operates the same as the right hand side, turning both on at once. I have pictures of the switch (might show the connections). Can I send them to you? – Lyndelle McMillan Aug 19 at 1:50
  • @LyndelleMcMillan Photos welcome. apptechnz gmail . || I take your operational description to mean that the LH side of the switch operates the outer element, which it shouldn't, as well as the inner, which it should. || I'd GUESS that this is due to there being contacts that disable the outer element and that these are operated by a "cam" on the lh side switch. | Alternative is an enabling switch for the rh side switch. | It seems likely that the contacts for this switch are "welded" together. If so, breaking the weld, then cleaning the contact faces may restore operation. Australia? – Russell McMahon Aug 19 at 7:01
  • Thanks Russell, I have sent you an email with the pictures. – Lyndelle McMillan Sep 25 at 4:24
