The side without the bead chain on my roller shade looks like this: enter image description here
How do I remove it? Google says to stick a flathead screwdriver into the tab between the bracket and to pull down on the bar, but it doesn't budge and I don't want to break anything; enter image description here
Here is the picture of the other side with the bead string - the reason I want to take it down is so that I can reattach the bead string
    it looks like the right side of the mounting bracket possibly slides towards you (away from the wall) .... it is also possible that you have to unclip the other end of the shade first
    – jsotola
    Jun 30, 2019 at 22:58
  • Let's see the bracket on the other side.
    – gnicko
    Jul 1, 2019 at 2:29
  • other side added
    – A G
    Jul 4, 2019 at 20:05
Thanks for great photos. Try putting the flat blade of the screwdriver between the metal of the end of the shade and the plastic bracket and gently pry the bracket away from the shade.
The tab needs to be pulled down (it may need to be moved sideways as in the second photo before it can be pulled out and the bar will slide down the notch.
