I have recently purchased a new AC. I opened it to clean air filters and found that an entire row of fins were bent. I asked the manufacturer about this and they said that it won't affect the performance or life of the AC. They say that this is normal and most of their new ACs have their fins bent like this.
I'm thinking of combing them to make them straight again. Will this damage the evaporator coil?
[1]
[2]
    Hello, and welcome to Home Improvement. Good question; keep 'em coming. And, you should probably take our tour so you'll know how best to participate here. Jun 30, 2019 at 12:12
You could follow the manufacturer's advice - they tend to know what they are talking about...
But if you insist on trying to straighten those bent fins, then use something that will not poke a hole in any of the tubes and go gently.
I have done this for similar heat exchangers with that type of fin and it is possible. Also for heat exchangers which have loops of wire, go slowly and carefully.
  • Won't it be difficult to clean these bent fins after few months of usage? Wouldn't the dust collected affect the performance and life of the product in the long run?
    – M.Tarun
    Jul 1, 2019 at 7:58
  • @M.Tarun but they won’t be bent...
    – Solar Mike
    Jul 1, 2019 at 8:23
  • I'm asking that if I don't straighten them wouldn't it be difficult to clean them? Won't the dust collected between these fins affect performance and life of product?
    – M.Tarun
    Jul 1, 2019 at 8:39
    @M.Tarun it will depend on how dusty and dirty the environment (your house) is.... If it is very dirty then you will need to clean it more often... I have seen some that have not been cleaned in years (like 10 or more) - just uses more energy...
    – Solar Mike
    Jul 1, 2019 at 8:45
  • We live near a power plant and we get lot of dust into our house. The air filter gets dirty very quickly and we have to clean it once every two weeks. Looks like it'll be better if we straighten them. I bought this AC because it's the most power efficient AC in our country. It wouldn't be worth the money if it uses more energy because of some bent fins.
    – M.Tarun
    Jul 1, 2019 at 8:51
This is normal and trivial damage from handling. Unless it significantly disrupts airflow, it won't harm the performance of the unit by any meaningful amount.
The manufacturer could put guards and ducting around these coils, however that would make the air conditioner more expensive. Was price a factor in your choice? If that is, then they had to hit that price point or you would not have bought the unit. So they cut corners on unimportant condenser shielding instead of cutting corners on compressor bearings.
    This is one of the most expensive Air conditioners available in our country. It's kind of expensive than other brands for the features it offers. I bought it thinking that their products are of better quality.
    – M.Tarun
    Jul 1, 2019 at 7:52
    @M.Tarun that’s marketing for you...
    – Solar Mike
    Jul 1, 2019 at 8:24
  • @M.Tarun Bent fins might not be the best measure of quality. As Harper points out, if they are spending the money on quality internal components when the competition does not, you are still getting your money's worth. Jul 1, 2019 at 12:35
  • Also, you can't go by price anymore. Our friends from a certain far-east country have learned to stick local-friendly brand names on their junk and charge premium prices for it. It's getting to where you can't buy cheap Cheese anymore... Jul 1, 2019 at 15:19
