this old house, ongoing issues. I'm having a hard time figuring this out, here's the story with the living room lights,
Lutron S-603P dimmable switch 600W max 5A
Charred copper ground wire. The ground connection was a little loose. Also could've been touching a hot wire?
Bulbs were barely lit and would fade out completely for a while but now nothing for a few weeks. Started to happen after a bidet was installed upstairs. These lights are the only things on a single breaker switch. Receptacles are on a separate one. However to give you an idea of the previous owner/workmanship the plumbing to the toilet came from the freaking fire sprinkler!! There's a colon blaster waiting to happen. Anyway....
Living Room
5 pot lights H7T 50W, R20 Max......
Bulbs: floodlight 45W 120V however all removed and installed a 60W bulb but still nothing.
Do I need a voltmeter? New dimmer switch?
    Can you post photos of the inside of the switch box please? Also, multipurpose fire sprinkler/domestic water systems are permitted by NFPA 13D (and not at all unheard of) -- a fire sprinkler system is actually not that dissimilar to ordinary plumbing, it's just that the fixtures are a bit funny looking :) – ThreePhaseEel Jun 29 '19 at 2:06
