I am preparing concrete slab surface for leveling it. I removed the tiles first, and grinded away the remaining thinset mostly nearby the boundary of tiles. Here is the picture of the current situation: enter image description here
The white area is where the grinder touched. The dark area is the original surface of the slab. My questions are:
1) Should I also grind the dark area to expose fresh surface?
2) If I do not grind the dark area, will it affect the leveling process and quality using the floor leveling compound? I remember before pouring the leveling compound, the concrete surface needs to be sealed. Will the dark area affect the sealing procedure?
  • that looks odd ... i think that you ground off the grout ... the old thinset is still on the slab ... that is the dark area – jsotola Jun 29 '19 at 0:21
