1800 sqft + basement
On main floor 2 window air conditioners 19k btu combined
Upstairs 1 5k btu air condition
There is 3 bedrooms upstairs, does it make sense to jist pit all the ac units upstairs and let the cold air drop down through the floor or to drill vent holes in the floor? Would this method actually cool the main floor or reduce humidity on the main floor? The stairway is pretty open so all hot air floats up here pretty quickly.
Just as the hot air goes up since it is lighter the cold air will fall since it is heavier. If by chance you have a forced air heating system, you could run the furnace fan while the A/C units are on to help distribute and mix all the air in the house for better comfort. My son did this in his house for many years and it worked fine.
