I'm attempting to find a green and cheap insulation for the roof of a school bus conversion I am building. Kapok is easily sourced for me as it literally grows on trees.
The dimensions of the roof are approximately 40' by 8.5'.
But what is the R-value of Kapok? Are there other cons I should be aware of?
    Generally anything that grows is a bad idea for insulation. Like the horsehair insulation of old, it will interact very, very badly with water -- it will invite mold growth. And relevant to you it will retain water, which means rusting out the bus body. Jun 25, 2019 at 17:59
    Also, since it is a conversion (to a place people are when not in motion), consider flammability - it could spread fire too fast to escape. A common source of fire is whatever you use to heat the space. Another is poisonous smoke which could hurt your escape chances by incapacitating you or doing long-term health damage. Aviation people pay very close attention to this. Granted organic things are less likely to be toxic, but far more likely to be flammable. Jun 25, 2019 at 18:03
  • Most insulation is cheap, usually the expense is down to fitting it...
    – Solar Mike
    Jun 25, 2019 at 19:18
  • as @Harper states, flammability is a problem, but can be helped by treatment, e.g. applying borates. Kapok is cellulose, so see this reference: insulationinstitute.org/wp-content/uploads/2015/12/… Jun 25, 2019 at 23:53
  • @DrMoishePippik That resource and clarification was super helpful. Please post it as an answer
    – Joe B
    Jun 26, 2019 at 16:47
As @Harper states, flammability is a problem, but can be helped by treatment, e.g. applying borates. Kapok is cellulose, so see this reference. However, the amount of fire-retardant used is ~20% by weight.
That said, kapok was the standard filler (in separate compartments) for life vests for many years.
According the the link, the R-value of cellulose is between 3.2 and 3.8 per inch.
Scientific paper on thermophysical properties of kapok
Research Journal of Applied Sciences, Engineering and Technology
  • You should put the relevant info in your answer, as links can suffer from link-rot...
    – Solar Mike
    Jun 25, 2019 at 20:56
