Our family room came wired for surround sound that we won't use (see pic). I know I can buy metal plates that screw into the boxes after removing the existing covers. As there's only speaker wires and no electrical, I'm comfortable doing this.
My question is that since we intend to put wallpaper on this particular section of the wall where those boxes are, I need to spackle over the wall plates I install. That is, I want to completely hide the speaker boxes such that when wallpaper is applied it will completely cover where the boxes were. Is there a way to do this to ensure the spackle won't crack and the wallpaper won't wrinkle over time?
Speaker Wall Plates
    remove the covers .... apply wallpaper to the wall .... wrap each cover with a piece of wallpaper is such a way that the wallpaper pattern on the cover is exactly the same as the pattern on the wall under the cover ... replace the covers over the boxes – jsotola Jun 25 '19 at 16:41
  • Sorry, I wasn't clear. I want to spackle over the covered boxes such that you cannot see them anymore. I want to hide them in the wall as we want the wallpaper to completely cover where the boxes were. – icfantv Jun 25 '19 at 16:48
  • Are you OK with completely removing them? – PhilippNagel Jun 25 '19 at 16:48
    @icfantv, your post is clear .... i was only presenting an option that you may not have thought of – jsotola Jun 25 '19 at 16:52
    cut a piece of drywall that fits inside the box opening and is flush with the wall .... install a small wooden block inside the box and secure the drywall piece to the block .... tape and mud – jsotola Jun 25 '19 at 16:58
In order to recess the blank cover plates into your drywall, you could try finding the smallest blank cover you can get. They do make them in smaller and larger sizes, though you may need to shop around a bit.
Once you found one that's smaller than what's on there now, install it on the box, and mark the outline on the wall. Remove the plate, trim the drywall around your markings, and re-install the blank cover. It will now be recessed behind the drywall, unless the box itself is exactly flush or protrudes out.
Now you could use tape and drywall mud to make the area flush and apply whatever covering you would like.
Alternatively, you could also remove the boxes completely, for example, by using a saw to cut through the nails that hold them to the joist and then pulling them through the hole. You would then place a thin, short board through the opening (like a piece of 1x4 ripped to fit easily, or plywood), and use that to fix some cut-out drywall into the hole, and then patch as you normally would. It would look something like this before you place the patch piece over the wood: enter image description here
| improve this answer | |
The best way is to remove box. Add a piece of wood for a backer. Make it longer than hole . Put a screw in the center to hold onto wood. Add screws into drywall, add small patch. Tape over with three coats.
