Please see the picture, what's the best strategy to fix this? The skin which is quite thick is peeling off but the back end is quote solid. I have stopped further water leakage.
Should I be cutting the dry wall piece and put another one or I can manage fixing it without that?
Should I rip of the nearest crown molding as well and put it back?
Or this project better left to a professional?
  • i would cut out a hole the size of the new drywall panel by tracing it. then you can just pop it in and re-mud. – dandavis Jun 20 '19 at 19:20
    I would remove the molding, and cut to the wall. Expose the area, ensure its clean, then repair along the seams, toe in 2x4 as needed to ensure a tight fit – noybman Jun 21 '19 at 2:31
  • Is that drywall? And the gypsum is discolored from the water? I would remove the trim as noybman suggests , 2 seams that will be hidden+ @noybman you should work that into an answer – Ed Beal Jun 21 '19 at 18:30
  • I was reluctant to make it an answer because I wasn't confident it was drywall, (does it contain asbestos maybe?) I was hoping someone else would pipe up. I mean, it DOES look more like drywall than anything else, but the super thick paint+paper layer gave me pause. Maybe the damage and discoloration is from sewer water – noybman Jun 22 '19 at 2:24
