Hi i want to move a junction box that's behind my back splash into a cabinet but so i should be able to access it as needed according to the code but the wires from the top and bottom are exact so i cant move it up or down does anyone have any ideas?
    Got any pictures? Are you mounting the cabinet over the backsplash? – Machavity Jun 20 '19 at 18:30
    is the existing one for a switch or socket? is the new one the same, just higher? – dandavis Jun 20 '19 at 19:05
    what kind of wiring? For NM-B (Romex), there are splice kits for in-wall splices on repairs, no junction box needed. There seems to be some debate as to if these are legal; consult your local inspector. – DoxyLover Jun 20 '19 at 21:20
  • Can you post a photo of the inside of the existing junction box? – ThreePhaseEel Jun 20 '19 at 22:23
I hesitate to give this information but you can use an approved splice kit in a wall per the requirements of NEC 334.40(B). It looks like this:
The reason I hesitate is because somewhere around 85% of all electrical problems are caused by splices. Every good electrician knows this. That's why we always try to enclose any splice and make it available for maintenance purposes. Also keep in mind that the NEC is a minimum standard and at one time approved Aluminum branch wiring. Meaning they may think it is a bad idea in the future and write it out.
So your best bet would be to find a way to run new conductors to a better location and protect it and make it accessible for maintenance.
By know you have probably guessed that I don't like them. I never had to use them. Granted it is more labor intensive and cost more, but it can be done. FYI if you will google in-line splices you will also find several sites that agree with my dislike.
Good Luck.
