Recently replaced an inline ball valve and now the well pump will not shut off when up to pressure. Since the valve wad the first from the holding tank i had to drain it. What's the solution to this issue. Any and all help is deeply appreciated
It sounds like you have blocked the pressure going to the pressure switch, if the valve is opened and your pump shuts off you will need to relocate the valve or pressure switch so the pump will shut off.
