There are two 2"x12"x8' stringers attached to studs in the garage with 1/2"x2-1/2" lag screws in order to mount a squat rack.
Is there any concern that I could compromise the integrity of the garage by removing removing the stringers?
  • Hello, and welcome to Home Improvement. If you like your answer, please click the "check" icon to mark it as the right one. And you should probably take our tour so you'll know how better to participate here. – Daniel Griscom Jun 15 '19 at 22:52
  • thanks @DanielGriscom, just waiting for someone to respond to my comment on the answer -- then I intend to accept – oso1965 Jun 16 '19 at 22:06
Unless there is more to this than you've shown, this was added AFTER construction to permit the installation of the squat rack. As such, it's NOT a part of the garage's structure and so removing it will not compromise it in any way.
|improve this answer|||||
    thank you for the quick response! just want to make sure as I won't be leaving the structure the same as initial construction: the holes left by removing the inch or so of lag screws won't affect strength of the studs? – oso1965 Jun 15 '19 at 20:15
  • Best answer vote and close topic ,No need for any more. – user101687 Jun 15 '19 at 20:21
