I need to install floor cabinets to concrete floor. I see that there is a suitable board on the top of the back of a cabinet to secure the top but was wondering about the base. Should I attach a pressure treated 2x4 to the cocnrete floor 3/4" (thickness of the cabinet) and inside the cabinet so that I can screw the cabinet base to it on the other side?
I can see no other way to affix the bottom. Unless the bottom, for some reason (the weight of the counter top) does not need to be secured.
