I would like to add a level to my cordless drill.
I saw this and thought it would work if I added it to the back of my drill.
I thought I would position the drill in the right position and then glue the level to the back of the drill to where the bubble is centered.
Do you think it would work?
Level
    that would definitely work ..... you would be able to return the drill to the same orientation as it was when you glued the level indicators onto it ....... use double-sided tape to quickly determine if the idea works as expected .... then use glue – jsotola Jun 10 '19 at 2:48
    you could also use this technique if you have to drill a bunch of holes at some specific angle .... just tilt the drill to the desired angle, glue the level indicator so that it shows level .... i'm sure you get my meaning – jsotola Jun 10 '19 at 3:43
    i would use poster putty to allow quick in the field re-adjustments. – dandavis Jun 10 '19 at 17:15
As Jsotola alluded to,
You would have to use a Long drillbit and Clamp it in a vice so that the drill bit is plum and true on all sides.
Then chuck the drill on to the drill bit.
Then you could glue your bubble on so that it is indicating level.
Good luck to you.
  • That's an excellent idea. I have a 16 inch paddle type bit. – fixit7 Jun 11 '19 at 3:17
I used a hot glue gun using the milky colored glue sticks.
