Is it possible to connect a fridge/freezer and a washing machine to a single cold water supply? I need to know what sort of adapter I would need for the water supply to feed both appliances.
Yes, this is usually possible as long as you have sufficient pressure and flow if they both run at the same time.
Examples are: push fitting with valve
threaded
| improve this answer | |
  • would be helpful if you added a googleable item name. I guess, that is some sort of "Y 2 Way connector" – aaaaa says reinstate Monica Nov 1 '19 at 17:43
