I've recently begun spray painting and realized that I should probably buy a gas mask to protect me from harmful solvents.
I read as much as I could, but since it's not my area of expertise, I would like to ask for someone more qualified than me to see if I made the right choice.
I chose a 3M 7503L as a half mask, with a pair of 3M 06915 cartridges Link in german for protection. I was not certain if this is the right filter for the job, or if this filter is compatible with the mask.
The filter states it's suitable for spray painting, so I guess it's alright. Then again, "I guess" isn't good enough for personal safety.
I also happen to have a thick beard, which could be a problem. And no, shaving it is not an option.
Edit: The spray contians the following:
- Acetone
- Propane
- Butane
- Xylene
- Isobutane
- Propylene Glycol Monomethyl Ether
- Petroleum distillates
