I have 2 heating systems:
- Drayton Wiser with 2 zones (to use for radiators and hot water)
- Heatmiser UH8-RF (to use for 3 zoned underfloor heating)
And I have one boiler for the whole house.
I want to connect both systems to the boiler.
My options:
Connect both of them to the boiler so that they can switch it on according to each own's programming. Is this possible? This would be ideal because it's the most straightforward but I do not know if this is possible and/or safe.
Connect the Drayton to the boiler and use one of its zones to turn the hot water on. This has only the problem that the 2 system must be in sync or I risk to burn the underfloor heating pump if it goes on while the hot water valve feeding the secondary system is closed.
Any Ideas? Suggestions?
