I tied into a water line that was capped off in my crawlspace. It is a CPVC water line that used to run to a sink in a utility room of my home. Water pressure when the line was connected was just as the rest of the home. I have now tied into this line and run CPVC pipe underground for about 25 feet and connected to a spigot. Water pressure from the spigot at best is a slow drip. I have checked all joints/connectors of the CPVC pipe and there are no leaks.
What do I need to do or check in order to get adequate water pressure?
EDIT
And for clarification the CPVC pipe runs about 1 foot down to the ground, then runs about 18 inches up to the spigot, the rest of the run is flat.
    Is it only the new line and spigot that has the low pressure issue? Assuming yes, I would turn off the supply and remove the spigot, then test by having someone open it up whilst standing at the open line with a bucket... May 31 '19 at 15:34
  • @JimmyFix-it - yes, it is only the new line that has the low pressure. I'll see if I can get someone over to assist with your recommendation this afternoon. :) May 31 '19 at 15:41
  • @JimmyFix-it - with the spigot removed, water pressure is still low at the end. Jun 2 '19 at 17:54
