I removed the toilet paper dispenser on the wall, covered up with compound, and sanded. I applied primer on the affected area but I painted the entire wall. So, now my wall is not consistent. Can I fix the problem by applying a few extra coats of paint in the area where I applied primer? If not, what is the best way to fix the problem?
Thanks so much!
