I need to cut some stiff sheet metal for roofing trim and the problem is dividing larger sheets. For example, I might have a sheet that is 6 feet x 12" and I need to divide it in half. The problem is that my snips cut a little ways into the sheet, but soon they get stuck and I can't push them in any farther.
A book I have on sheet metal says that one side of the cut is supposed to "curl" away as I cut, making room for the shears and I am supposed to cut so that side is the narrow "waste" half. But in my case I am dividing a wide sheet, so there is no "waste" strip, both sides are wide.
I can see that if I was just trimming off half an inch, then it would peel away, but when both sides are 2-3 feet wide, that doesn't happen. So, how do I divide the sheet?
