Amateur here.
I have a house where the chimney run framing extends to the basement (rather than simply sitting on a platform attached to the main floor). The only fireplace present is on the main floor. In the basement it's just an empty alcove.
There had been poor sealing at the trim boards and a gap in the gutter line where it met the chimney run that allowed water into the walls during heavy rain. This had lead to termite damage (no termites around at the moment, due to ground treatment outside no doubt) at the corner of the alcove. It looks like I'll have to replace the top plate (both boards) in the corner for both walls.
My main question is this:
1) The lower plate is easy enough to remove, but the upper plate is attached to the adjacent walls. Should both be removed in their entirety and replaced or is there a banding method I could used to replace just a foot or so of damaged board (in both walls).
bonus question: given the deck is attached to the outside of the house (along a 20 ft span, meaning load is distrbuted to other sections of wall) and it sits on the brick exterior, would this make you sweat more or less about support while replacing. note that what is in the pics below is basically how I found this, minus the very rotted corner studs that I removed...with a vacuum cleaner.
Note: it does look nasty up there from the pics. In the recent past, I replaced the trim and siding on the back of the chimney behind the fireplace and I got a good look on the inside of the chimney itself. I cleaned out a lot of sawdust, some roach droppings, and dead wasps, but there was no damage that I could determine. The damage seems to stop at the plate.
Corner close up
a step back
Note the runoff marks. I've patched the moisture issue by fixing the flashing around the gutter, and sealing and adding flashing around the brick (not visible here) Will probably just put a roof over the thing once I shore up the walls.
Exterior showing runoff
outside of chimney from top deck added per request. The damage is underneath this corner but lower down behind the brick. Note that the siding isnt damaged at the bottom, it's just a streak of dirt from the wife's planting
  • More pics would help outside of deck and chimney ... And what is above top plates another bedroom or attic ? – user101687 May 26 '19 at 23:14
  • Hi Robert. Above the top plate is the cavity where the fireplace sits. I'll add a picture of the deck an chimney above – John May 26 '19 at 23:48
    It is a bit more involved than just replacing the framing since this is an outside wall, very important to note with a brick veneer cladding. There is evidence of tar paper that was the moisture barrier so when the brick gets soaked when it rains, it does not get to the sheathing nor framing. This will take some detailing to get the integrity of the weather proofing intact. – Jack May 27 '19 at 1:17
    #1 are all the leaks fixed? If not you will be doing this again. Im not a fan of under the deck water looks like comes dwn deck sit on top of tha bump out and slowly works in check it out caulk and water wii seep in brik add sealent and flashing to push away – user101687 May 27 '19 at 1:24
    I was just getting to that, water my be coming in from top of chimney running inside of the siding . May need roof cap and flashing.. also under that deck to. – user101687 May 27 '19 at 1:35
